F3 to F4I swap
F3 to F4I swap
I know im prolly posting in the wrong are but im new to the forum.
I want to swap all the fairing and gauges on my bike to the F4I, i have a 94 F2 that has been completely swapped out to an F3 engine,trans,harness and all. ive done a little research into the fairing swap and i have some questions about the tail and the headlights.
1. it the tail a bolt on so long as i dont go with the split seat?
2. Is the headlight mainly bolted to the fairing like the F3 is or will i have to modify my fairing stay?
i would really like to see some pics of the proccess or at least of the F4I parts in question so i can see what ill have to work with.
Thanks for any info in advance
just depends on how much free time you have and how mechanical you are! Never done f4i fairing but search for it we have a few members that have done it, and blended some f4i fairing with r1 fairings. Different tail fairings too. It can be done and has. NO to the gauges....just no! Engine harness.....your on your own! Keep in mind that you will run into problems with the swingarm.Not a straight up swap!
Pretty sure if you've done airbag setups and the trick push-pull levers on minitrucks,you should have no problem with these but machine work! https://cbrforum.com/forum/images/icons/icon10.gif
from what i have researched on you have to use the F4I's subframe if you want the split seats and since the F3 or F2 has a welded subframe you would have to cut it off and reweld the F4's on or weld tabs for the F4I subframe to bolt to.
