F3 to F2 front
just a ideal you could get a heads up display for your helmet http://www.sportvue.com/store/product.php?pid=15and it would save alot of extra work , just a thought
as long as you set it up right its more accurate than the stock speedometer, and if you decide to change the gear ratio -1+2 popular conversion it still reads true, the only problem i have is the gear position does not read right all the time, but its nota big deal to me i just wanted it for the MPH and radar detector, if all you want isMPH you can get the mc1 instead of the mc2 the only difference is about 100 dollars and the mc2 supports radar detectors, both have the same issue with showing the correct gear your in, i think I'm going to contact the company to see if i can disable the geardisplay part, also it works well in most daylight conditions except for when the sun is directly in front of you then it whites out the display, also if you run 2 different visors tented and clear day / night use then you need to order a second mount for the display unit, other than that i love mine i can keep my eyes on the road better i know for a fact its saved my @zz twice cause if i would have glanced down at my speedo i would have been road kill, i hate people that dont look before they pull into traffic guess their radio station or cell phone call is more important than my life.
anyways you can find them on ebay from 150.00 to 300.00 just depends on which model you chose, hope it help best of luck
the reason you get a left and right mount is because you need to do the eye test to see which side you mount it to http://www.sportvue.com/support/dominance.php
