F3 Engine Rebuild
Old 12-29-2010, 04:02 PM
cgmiller83's Avatar
Something so small the dealer wants $6+ each. The refill kit has 35 shims and breaks down to $1.20 each. The OD is 7.48mm.
  #42
Old 12-29-2010, 11:18 PM
Project96's Avatar
Sometimes you can go to the dealer & swap the shim to the ones you need. Depends on how much of an a** the dealer wants to be.
What kind of cams are you running, & what are you degreeing them to?
As for the degree wheel, is it one sided? The one I have & ones I have used in the past past are double sided. Where one side goes one direction & the other side goes in the other direction. Thinking maybe you could use the flywheel side instead of the reluctor side. Using the reluctor side is not a must as long as you can get your TDC zeroed in.
  #43
Old 12-30-2010, 04:54 AM
cgmiller83's Avatar
The APE degree wheel is one sided but the way the markings are done its not directional.
I have an idea of what the numbers are going to be. That may change when I check the valve to piston clearance. Alittle bit of a secret right now. All I can say is it going to be a pain to get the jetting dialed in just right.
  #44
Old 12-31-2010, 12:30 PM
cgmiller83's Avatar
Well to my surprise today the valve shims came in. Guess I know what I'm working on this first weekend of the new year.
  #45
Old 01-02-2011, 07:15 PM
cgmiller83's Avatar
Finally got the head back on. Here are some pics.
Used the large stock engine spacer to mount the degree wheel. Seeing as I made aluminum replacements.
Installing the head bolts. Be sure that the allen socket is in all the way.
Here's what happens if you don't have the socket in all the way. I did this when I was taking the motor apart. I won on Ebay a box of hardware from an F3 last year. Good thing I remembered where the box was.
Everything torqued to specs.
Easy way to get the old cam gears off.
Who doesn't like new parts.
Size:  118.4 KB Bolting down the cams.
Now the fun part, adjusting the cam timing. Be ready to loosen and tighten the cam gear bolts many times.
Cam timing done. Not something I want to do to many times. The degree wheel off and installed the ignition advance rotor. I use the Factory Pro since you can adjust it in one degree settings. -6 to +6 Before the rebuild I had it set at +4. Ran great so a good place to start.
Valve cover back on. What else to say.
Put rags in the intakes to keep things from falling in.
Must have when its only 20 outside.
  #46
Old 01-02-2011, 08:07 PM
underground-mpyre's Avatar
Looks great! That motor will be better than new. I am truely impressed.
  #47
Old 01-02-2011, 09:55 PM
billetproof97's Avatar
Man your working fast on this.
  #48
Old 01-03-2011, 05:00 AM
cgmiller83's Avatar
I only really work on the bike about every other weekend. Saturday I only worked on it for a couple hours. Propane tank ran out. Did most of the work Sunday, with a new tank. 75 vs 20 degrees is so much easier to work in.
Now I'm waiting on my parts. Trying to choose which race body work I'm going to use. Thinking about using 05-06 CBR600RR.
  #49
Old 01-03-2011, 10:20 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
this has become my favorite thread in a long time.
*gets comfy and waits for more pictures*
  #50
Old 01-03-2011, 02:33 PM
Project96's Avatar
Are those stock cams? If not who's are they if I may ask? Did you do any head work on the ports?
Quick Reply: F3 Engine Rebuild
