F3
Old Mar 16, 2011 | 12:05 PM
Pressure's Avatar
Default F3 tire size and exhaust placement
Hey i have a1995 honda cbr f3 and i want to so some modification. first of all i want to change the rim what is the largest size rim i can fit on the stock swingarm. secondly is there anyway i can get the exhaust higher.
Old Mar 16, 2011 | 07:24 PM
billetproof97's Avatar
I've seen a wider 5.5 rim on the f3 but I haven't seen "bigger rims" on these bikes. Why change it? Stock wheels work well. I haven't seen a high mount exhaust for f3 you could fabricate a bracket and make the midpipe flow up toward the rear and slip the muffler on.
Old Mar 16, 2011 | 07:29 PM
Pressure's Avatar
i want to put a wider tire on the bike...stock is 160 i wanna try 180
Old Mar 16, 2011 | 08:12 PM
You should have said tire. 170 is as big as you can go on the 5in wide rim. Get a 5.5 wide rim and you can run a 180. You can do a 180 on a 5 in rim but good luck changing the tires out every couple thosand miles. The outside of the tire wears down.
