f2 fairings fit a f3?
Guest
Posts: n/a
yes they have mostly the same mounting points. the exception is that the f3 has ram air and the f2 does not. so you will either have to re-route the ram air ducts on the air box or remove them. just remember if you remove the ram air you will need to adjust the air fuel ratio on the carbs or you'll run a little rich. also the tail light and tail fairings on the 97-98 f3 are different than the 95-96 f3 and the f2 so if you change the tail fairings you'll have to change the tail light as well.
nowensby
Nov 26, 2024 02:28 PM
Rozenheimer
Mar 6, 2009 06:35 PM
