Engine Ticking Noise CBR600F3
I have some new plugs I will fit soon. The bike seems to run fine on a gravity feed strait from the tank.
Does anyone know what I am checking for if I remove the CCT?
Thanks
So with the manual ones, how do you know what the correct tension is? Do you just screw it in until tight?
Well the fuel pump issue is fixed now. But my engine is still tapping like something else. Doesn't seem to matter whether its hot or cold, but I'm sure its getting louder. As i previously mentioned, i can hear it most when pulling off from lights and accelerating. I cannot hear it when the engine is decelerating. If it was the CCT wouldn't it make the noise all the time? Also, if it was a bad valve it would also make the noise all the time? I'm thinking its maybe a loose inlet rubber on one of the carbs? or a leaky exhaust gasket. I have bought some new exhaust gaskets, but it looks like a right PITA to fit them.
