Engine Ticking Noise CBR600F3
Hello people,
Been lurking around for a while here but thought I would fire a question out there.
I picked up my first 'proper' bike around 2 weeks ago, a 1997 CBR600 F3. Great bike, I love it. But in the last couple of days it seems to have developed a fairly loud ticking noise. Now I am worried there is a problem with the valves. I have read many other posts about this and I do not believe it is the CCT as its a tick, rather than a rattle. The bike has done just over 40000 miles and doesn't seem to be down on power and runs and rides perfectly. I can hear the ticking most when pulling off in 1st and up to around 3500 RPM. I cannot hear it when changing down and decelerating - which leads me to think its not a valve problem? I have ordered some exhaust gaskets and some new plugs which I will fit this weekend. Anyone have any ideas, or seen this type of thing before? It is audible at tick over and seems noisier when hot. I think the oil was changed just before I got the bike and the oil seems very clean.
Any help would be much appreciated.
Thanks
Rob
Thanks
Rob
Yes it will crank fine. I have gravity fed the fuel strait to the carbs and it runs fine. The fuel pump will also turn if i wire it directly to the battery, but when i plug it in normally, it will not turn. I am thinking the fuel pump relay is faulty? I have checked the fuse.
Thanks for your help!
Hmm...
and the fuse was good ? Just try to change it with other. I'm sure you have another in your garage.
The relay is good suggestion, but on my F3 someone was removed that relay and wire the pump direct to contact key. :X So I don't know where's that relay.
Ps. What's CCT ?
Ps. What's CCT ?
Thanks
