Electrical: Over 21v+ @ 3000 RPM WTF?
Ok, so my headlight died the other night. Likely a voltage spike. We all know that. Today, I decided to take things apart and dig around. I did a voltage test with the bike idling. Got 13.xx volts. So I revved it up to about 3K and noticed around 20(+) volts, then back down to 13 when I let off the gas.
Like some of you mentioned in my headlight popped thread, I'm thinking "stator" is the problem. Now with this new info from today, can any of you give some thoughts before I just go out and buy a new stator?
Is there a good way to test what's coming out of the stator, like at the plug under the tank?
RE: Electrical: Over 21v+ @ 3000 RPM WTF?
take a look at your regulator/rectifier for "heat damage" like melted wires, plug or the R/R itself. Mine went bad and I I thought it was the stator, replaced that and it still would die. Got to checking around and the regulator was fried...literally! the plug had got so hot it nearly fused itself to the rectifier and I like to have not got it unplugged. I had to end up replacing the plug due to melting and the rectifier because it went bad and caused the damage. Mine was running fine, went riding, stopped and got gas, cranked up rode some more, let it go dead at a stop sign and had to push start it (battery had went dead), went about 1/4 mile and started dieng out and finally all dead. Replaced stator &charged battery,lasted 1 day....dead again That's when I found the R/R melted.
ORIGINAL: fiddy pimpin
I guess in some instances it could be the stator...however the r/r is the usual culprit[sm=massbounce.gif]
Is there a way to test just the stator?
http://cbrworld.net/forums/thread/140473.aspx
Check that out man, it helped me when my r/r took a ****. Good luck man
I was reading that when the regulated voltage greatly exceeds the standard values, the continuity between the ground line of the R/R connector and the frame should be checked. If the continuity is incorrect (meter does nothing),there is an open circuit in the harness or a poorly connected connector. If the continuity is correct (meter chimes), it is a faulty R/R or a poorly connected connector. I was having charging issues (battery was dying) and found the connector between bike harness and stator melted. Granted, that was the connection for the three poles but you might have something similar.
Just one question, are you buying the cheap R/R's fromHong Kongon eBay? They could be bad from the get go. I had to replace an alternator for a friendfour times (I'm a sucker for the hotties) becauseshekept buyingcheap POS. Once she dished out the cash and boughtthe alternator I told her to buy originally, there was no need for a fifth alternator. I must say, this is the FIRST time I have read were someone's charging system was overcharging. Good luck!
I'm using "Electro Sport" replacement r/r's. I've heard they are decent, and only about $100. They have much better cooling than the stock unit I took off.
You have me thinking now. I may get out there today and just go over EVERY wire and connection related to the charging system. I already have all the skins off anyway. Maybe I do have a grounding issue somewhere.
Any input on the Electro Sport units and their quality?
