Does fork oil need to be changed if seals don't leak?
I have a 96 f3, the people at the shop are trying to tell me that I should change the fork oil ever ten thousand miles. However, Honda goes out to 24,000 miles in their manuals and only lists inspections. So should I go through the effort to buy long ratchet straps and do it (garage rafters are like 10 feet tall), or should I just let it go until a seal has gone on it. Also, if I don't need to change it, is there a way to at least check the level without lifting the bike so I can be sure they're at the right level?
wassup man,I just changed my fork oil this weekend.You'll be amazed at what a oil change can do as far as feeling in the front end.It's like night and day!!!! took off the headers,placed a piece of 2*4 under the oil pan,rear jack stand on the back,took of front wheel and brakes. bleed the brakes as well.If you can change car oil you can do your forks!!! Its that easy,once you do it.
In your case I don't think you should be looking at the mileage but how old the fork oil is. I don't know if your the 1st or the 6th owner of your F3. Either way if its never been changed that oil 15 years old. I'm surprised the seals haven't started leaking. I would take them apart completely. New seals, fork oil, inner and outer bushings would be what I would do. Plus since you have it apart. If you don't weight in the 150-165 lbs range. That would be a good time to install the correct rated springs.
i know dirt bikes arent the same but i did front forks twice a year and rear once. so i did the front on my f3 last year {when i got it} and recharged the rear! so i figure this year i'll do front and rear{so there both fresh} and get on a 2 year suspension oil change schedule!!! right or wrong thats my plan!
