deleting kickstand safety switch?
RE: deleting kickstand safety switch?
You'll have to look in a manual and follow the wires up. Honda seems to like over engineering on little switches. One of the wires is a 'common' and depending if the switch is open or closed it's connected to either the second or third wire. You can trial-and-error it pretty quickly if you don't have a schematic available. Just put the rear on a stand, put it in gear, connect two of the wires and hit the starter. If it doesn't turn over connect two different wires. There's only 3 possibilities.
ORIGINAL: DirtyZ
It's a 3 wire sensor. green, green/black, and a yellow. Yeah, if it was two wires I'd already have it done. I tried a few things with it. One probably goes to ground.
