clutch cable
Old Apr 2, 2008 | 03:23 PM
mccannf3's Avatar
Default clutch cable
Hi there, I have a post in the General tech section but wanted to post it here also because it is an F3. https://cbrforum.com/m_527539/tm.htmThanks in advance!
Old Apr 2, 2008 | 04:30 PM
Trouble's Avatar
Default RE: clutch cable
It's a wet clutch, try putting oil in and starting her up, see what happens.
Old Apr 3, 2008 | 06:53 PM
mccannf3's Avatar
ORIGINAL: Trouble
Isn't the main purpose of the oil for cooling?? With or with out oil it should still feel normal mechanically right?
Old Apr 3, 2008 | 07:13 PM
pr0jktmayhem's Avatar
oils pretty bad for cooling get hot ashell.
for lubrication
Old Apr 4, 2008 | 12:10 PM
mccannf3's Avatar
ORIGINAL: pr0jktmayhem
for lubrication
I'm pretty sure that is its purpose? Obviously oil is a lubricant, that is also why it is used, but soaking the clutch components in oil also cools them (stabilizing them at a specific temp) I know the friction caused between the steels and friction plates is a lot hotter than the oil. Any input on my clutch cable issue?? I know I can not be the ONLY person who has had this happen? What about the possibily of the pressure plate? I know the spring bolts screw into it. I'm sure there is a discard spec, anyone know what it is?
Zandaloo
Aug 22, 2013 03:26 PM
fbpsb82
Jan 30, 2010 02:23 PM
lsybert
Jun 25, 2009 11:07 AM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
