Choke adjustment?
Old Mar 28, 2017 | 01:29 AM
danroonie's Avatar
Default Choke adjustment?
I've revived my F3 after several years on moth ***** -a carb was leaking and I had some other issues I fixed. It starts off gr8 but if I turn off the choke it stalls. So I don't turn it all the way off. Is there a choke adjustment or is there something else I should check?
Looking forward to some long worry free rides
Old Mar 28, 2017 | 06:59 AM
Hey there. Glad you are getting your bike on the road again.
There isn't a way to adjust your choke other then what you have on your handle bar.
I do not believe the choke is your issue. It sounds like you need to clean the carbs thoroughly. If she sat for a long time with any fuel in her, that is what is needed.
Old Mar 28, 2017 | 02:36 PM
Your idle circuit is most likely clogged. Needs complete disassembly of the carbs and the bodies soaked in carb cleaner. Make sure you remove the idle-air mixture screw too.
Old Apr 28, 2017 | 05:08 AM
Cyriel Gaemers's Avatar
If you need help via chat/email/whatsapp, let me know, just did this last night.
https://cbrforum.com/forum/cbr-600f3...9/#post1303954
on the other hand, my choke cable is not tension(ed) *Sorry for bad english now, i need to see where to tension this.
mbrown22
Nov 23, 2010 10:37 AM
dalves11
Sep 22, 2010 04:47 PM
MapJr
Dec 6, 2005 08:08 PM
CivicRacerX7
Feb 11, 2005 09:18 PM
