Cheap way to replace your keys
One thing I noticed since I look at everything way too closely is that the key has a code on it, this code also matches the code that can be found underneath the gas filler when you either open it with the key or open it with Allen wrenches when you've lost the key. This code can be taken to the dealer along with the year of your bike and can be used to cut a brand new key for $10 that will work on all the locks on all three locks on the bike, much cheaper than replacing it all.
At least here you can walk into a locksmith shop (usually has a little booth in the lobby of a supermarket), give them the key and get a copy for a tenner no questions asked. The only situation they need to see the pink slip is when the key has a chip.
I got this trusted shop where I make all my keys. They have a device that tells them the "code/recipe" how to make the keys, but there's this young guy working there who doesn't use them. He looks at the key and "reads" it with just his eyes (at least ABLOY-keys for out doors here dont have the code written in them) and makes the copy "from the hip". Works like charm every time. A good thing you brought this up. Gotta make copies of my bike's keys before i lose them. Came with only one set. |
Well honestly I was thinking more from the threads I saw in the past where people lost their keys entirely, this is how you get keys made if you have none at all, you just take the gas filler off the bike and it has a code, very helpful also to people getting a good deal on a bike cause it doesn't have keys, could save them a couple hundred.
Besides making a copy of the key, it's a good idea to write down that key code
somewhere you'll find it later, to avoid those scenerios. Redundent, never is. lol And while there's a way to remove the gas cap without a key (spiceymeow, did a write-up) it's a PTA because the allen screws only hold the hinge to the bike, the cap, itself, locks down to the tank. So the allen screws will NOT release the cap. Thus, making it difficult to see the key number printed on it. Ern |
Remove the ignition and put a 3 wire switch in its place and BAM keyless ignition! Just hide it well.
anyone know of a dealer near jacksonville fl that still does this? i just called honda of jacksonville with my code(s) in hand, and they said that they dont have the means of doing it (honda no longer supplies key cutters)
You can buy blanks on e-Bay and take them to your local locksmith who should do them cheaply. |
Originally Posted by Shadow
(Post 1129300)
Most good locksmiths will have a code cutting machine and will use your code to cut the key, so it won't be a copy.
