Is changing sprockets worth it? - CBR Forum - Enthusiast forums for Honda CBR Owners
Old 10-30-2018, 04:28 PM
Default Is changing sprockets worth it?
So I've been contemplating making some minor mods to my '95 CBR600f3. I came across some folks changing out their sprockets for a little quicker low end speed. -1 tooth in the front, +2 teeth in the back. I don't do much highway driving, just having fun on the streets.
Any opinions out there? Is much of a speed increase? Is it worth the loss of top end speed? Does it do much damage to the engine or other parts?
Thanks guys!
Old 10-30-2018, 05:55 PM
74demon's Avatar
It's worth it. Give it a try. If you don't like it, you can always go back, easily.
Old 10-30-2018, 09:10 PM
Do you recommend replacing the chain with the sprockets? I seen this suggested
Old 10-31-2018, 09:48 AM
74demon's Avatar
Depends on what condition your chain is in. If it's old and worn out, you could use a new chain anyway. Same with your sprockets. If they are worn, they should be replaced. If they are are in top condition, you can continue to use them.
Sometimes, new chains and sprockets are available together in a kit.
Old 11-03-2018, 08:47 PM
sjona2011's Avatar
Do it. on paper, your top speed with suffer. In reality, you wont notice at all.
Old 11-04-2018, 03:26 AM
Registered Users
Default 1 tooth less front
Going down 1 tooth on the front is like going up 2 on the back sprocket and will put the Speedo out
Old 11-04-2018, 08:55 AM
And what is the normal adjustment for the speedometer getting off? Is it small enough that itís ignored or do you usually do something mechanical to adjust for that?
Turbulenz
Riding Gear
07-25-2010 11:29 AM
Micro Rotors
10-26-2007 08:32 PM
will_f3
06-02-2006 08:29 PM
mirks
04-13-2006 08:14 PM
rrasco
04-08-2006 02:02 PM
Quick Reply: Is changing sprockets worth it?
Featured Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
