chain and sprockets?
ok so i just bought a 96 F3 that's in desperate need of a new chain. so i ordered the chain and sprockets (one down and one up) but i can't find ANYTHING in the manual about changing the sprockets. i'm pretty mechanically inclined, so i'm sure i can figure it out, but i just wondered if any of you guys had any helpful advice as to what's involved. so far i'm familiar with taking the rear wheel and fairings off with no problem... where do i go from there?
RE: chain and sprockets?
You'd need a shop manual for all the details such as torque for the rear sprocket nuts and the counter sprocket bolt. It's pretty much straight forward -- take off the front sprocket bolt first. That way you can use the rear brake to hold it still while you loosen the bolt. Then loosen the chain slack adjusters and remove the axle.
bla who uses a shop manual i mean really....... personally i didn't use a shop manual i just made sure i got them nice and tight and then i rode it about 2 hours and checked them again and then again after about a week but that's just me... as for everything else i think it was just said my chainstretcher......
Here is a link to download the shop manual.
Removing the sprocket is in section 13-3.
Good luck!
https://cbrforum.com/m_4685/tm.htm
Good luck!
ORIGINAL: 1badf3
ORIGINAL: 1badf3
Please try not to trip over my soap box on the way out...
Torque??? I GOOD mechanic can look at the bolt size, the thread size, the material and know how much torque it can take. Maybe for a head you should torque it but sprocket bolts... come on. If you take it to a shop they will not torque them. But if it makes you sleep better at night go for it. If you are in question just torque them to spec or a little more. Torque wrenches can be off by more than 10%. Threads and bolts can take alot more than what the spec is. When I build an engine I only torque the head and crank. Everything else is feel.
alright well thanks for the advice guys. of course i'm gonna use the torque values i'm not that dumb. and i've got the manual it just doesn't really give much information, just wasn't sure if there were any special tools involved and whatnot. i have a cutoff wheel to cut the chain off, and i'm assuming that will be adequate and i won't need a chain breaker.
