CCT
Old Aug 12, 2007 | 09:29 AM
madmike01uk's Avatar
Default CCT
From reading posts on here I understand that when the CCT is on its way out you here some rattling noises coming from the right side of the engine (where the CCT is obviously) my question is that when the CCT is ****ed, if you hold onto it and rev the engine will you feel vibrations on the CCT? (I didn't on mine) I don't think mine is on its way out, was just wondering for future reference to look out for it.
Cheers
Mike
Old Aug 12, 2007 | 10:08 AM
patman's Avatar
Default RE: CCT
i think it happens around 15,000 miles, i'd keep an eye out around then
Old Aug 12, 2007 | 12:55 PM
Sand.Man's Avatar
Default RE: CCT
Mike, if you hear the rattle it is time to change it for a manual CCT.
Even if you dont hear the rattle, it's just a good idea to put the manual CCT in there, if that chain skips it will destroy your engine, not to mention how annoying that rattle is.
You'll notice that the CCT is letting go when you hear the rattle when the engine firststarts up, some rattle at idle and some rattle at mid-range RPM also. The sound is the slack in the chain slapping inside, and when the CCT loosens up enough the chain will skip a tooth on the cam sprocket causing the timing to go out and the pistons will come up and destroy your valve train and possibly the piston heads.
A manual CCT will keep constant tension and only needs adjustment a couple of times per year. If in doubt, swap it out! It could save your engine.
Old Aug 12, 2007 | 02:02 PM
Default RE: CCT
Cheers I don't think mine needs changing and to be honest I will change it with an OEM one when the time comes because 15000 miles is quite a long time where bikes are concerned, my bike has only just done over 13000 miles and there is no rattle or vibration coming from the CCT so it should be ok for a while.
Old Aug 12, 2007 | 02:45 PM
Sand.Man's Avatar
Default RE: CCT
Yeah youshould be fine for now, it's just an inherent problem with the early CBR's and one of the most popular mods.
Good luck! When I got my bike it only had 26,000 km's (Canadian) and it had the rattle pretty bad... Every time I fired it up cold it sounded like one of those little party noise maker rattle things!
Old Aug 12, 2007 | 06:18 PM
land_warrior.rus's Avatar
Default RE: CCT
+1 on Manual CCT
Old Aug 12, 2007 | 09:35 PM
FoxRacin17's Avatar
Default RE: CCT
how do you know if it is stock or a new manual one? i just got mine with 23,000 miles on it so it robably already has it done but id sure like to check it out.
Old Aug 12, 2007 | 10:41 PM
patman's Avatar
Default RE: CCT
anybody have the manual CCT done? whats the cost and adjustment process?
Old Aug 12, 2007 | 11:01 PM
Sand.Man's Avatar
Default RE: CCT
I just ordereda manual CCT, they're $49 american.
Pretty simple do-it-yourself install, would take maybe an hour.
Adjustment is just turning a bolt.
Old Aug 12, 2007 | 11:08 PM
Sand.Man's Avatar
Default RE: CCT
FoxRacin, you'll have to pull off your gas tank, or maybe just the side fairing and take a look at it.
If it looks like the one I just posted above it's a manual CCT, the stock one looks like this:
