CBR Parts Interchangability?
Old Aug 11, 2006 | 12:40 AM
PitterF3's Avatar
Default CBR Parts Interchangability?
My right side controls are all rashed up and the throttle tube binds up in the housing (I need to WD40 it to pass tech at the track). Will the controls from any/all of the other members of the CBR family work? Obviously, I need the electrical connections to work as well as the throttle cables. I'd LOVE to get the 1/4 turn HRC makes for the F4i but I'd be happy with anything that works better than what I've got.
Old Aug 11, 2006 | 05:31 AM
gerharddvs's Avatar
Default RE: CBR Parts Interchangability?
Hi,
Before you go and replace everything… I had the same problem on my F3. I cleaned it, put oil on the cables but it still was sticking. Then I discovered that the tension on the cables was set to tight. The thing is because you have two cables coming from the carb, you must give one of the cables I little slack else it puts to much strain on the cables and the throttle mechanism, and then it jams. I set the cables till it had about 1 or 2 mm play and then it was working perfectly.
Try it. Hope it helps.
bindelsf2
May 11, 2012 08:07 AM
1987HurricaneCBR
Nov 6, 2011 11:30 PM
bhhacker
Mar 5, 2007 02:12 AM
f4istunna
Feb 28, 2007 10:54 PM
demonchild
Dec 18, 2006 09:45 PM
