CBR...from hell
CBR...from hell
GOOD GOD I am sick of this bike. Not neccessarily a rant, but I will just say that at almost the same amount of miles (And yes I realize this reflects how the bike was treated to this point) but my other bike ran 10x better than the CBR. I never had to choke it or anything to get it started. It seems like every other day there's something wrong with this thing starting.
Like just earlier today i got it to idle, took it for a ride around the block and BAAM fuel cut out. No idea why. Had to push it 2 blocks. It's 70F degrees so deffinetely not cold...
It just feels like if it's not one thing or another electrical or carb related this bike is trying to kill itself.
on
1 Post
RE: CBR...from hell
Yeah, it happens sometimes, had a VW kombi van, that would not stay on the road for longer than a trip to the shops (or it seemed that way) Clutch cable, clutch, startor, stator. Had a new motor (& I mean 'new') put in it after all that & it dropped a valve about a week later.
Bastard even threw me down the road once, when I got a flat tyre I was trying to loosen the wheel bolts, all my weight to get them loose & the friggin wheel ratchet snapped & I went flying down the road on my back. Some vehicles are just cursed
RE: CBR...from hell
pull the carbs and clean them if you haven't already. it's easy and very effective. especially if you haven't yet. these bikes are pretty simple and you'd be amazed how much better it'll run if you clean out the top end and sync the carbs...also super easy. i can send you a list of home depot crap you need to make a carb sync tool...5 minutes of setup and screwdriver adjustments and it'll be a brand new bike. have you changed your plugs?
RE: CBR...from hell
Plugs are brand new.
I haven't synced these carbs, but i've done it before on my bike.
Either way the bike needs to be running for me to sync them..and it's not so I can't. I will probably pull the carbs and clean them.
And whoever said I bought a POS is right...this thing is a ragged out junk [:'(]
RE: CBR...from hell
ORIGINAL: Adionik
