sickCBRkid |
08-08-2009 07:49 PM |
cbr f3 floods cylinder please HELP !!!
I have a 96 cbr f3 that is one headache after another...my main problem now is that the #3 intake manifold cylinder floods and nearly hydrolocks my engine....a little back ground on the bike= my fuel pump has a short somewhere so I gravity fed the carbs (which I have dissasembled and cleaned Several times recently) my thought is the gravity fed tank is overpowering the float needle but why would that only fload #3 cylinder? The needles and seats look good and the floats don't Stick...plugs are new...the petcock does leak from a bad oring but not bad enough to flood carb...and btw. I was riding the bike for a week or two with gravity fed carbs the all the sudden while riding it sounded like I dropped a cylinder and bogged down 5 miles from home ..it made it home then after parked I noticed fuel leaking from the #3 intake manifold overflow nipple just under the carb boot...which has no cover on #2 or #3 but #4 is covered with a nipple boot...wierd....so I changed the oil and unlocked the engine put a new cdi box in and started up the bike just to find the fuel leaking again from that same nipple on the intake manifold...will a tank less than half full overpower the float one one carb when gravity fed ??? And if so why would it run fine with no leaks for 2weeks?? Also if my fuel cut relay was bad would the bike still run??? Cuz I want to fix the fuel pump to rule out the gravity feed scenario...I have 2 fuel pumps that work when wire to a battery but when plugged into bike harness the bike dies...and only allows 1 click on starter button then u have to switch kill switch off then on for another starter button attempt..but when fuel pump is unplugged from harnes (black/blue and green wires) the bike starts and the starter can be pressed as many time as u want without having to reset the kill switch inbetween clicks...so I think its prolly the fuel cut relay that's bad but today I got it to start with normal set up (fuel pump istalled ) but the pump still wouldn't come on...iknow because I have clear fuel lines and know the pump doesn't always come on but it was letting the carbs run dry and not pumping any fuel to them while bikewas running...the 2 wires from the pump are black/blue (goes to fuel cut relay on subframe) and green (goes to cdi box next to cut relay) ...so basicly I need to know how to tell if the fuel cut relay is bad and why is my #3 cylinder flooding. And do I need nipple covers on all 4 intake manifold overflow nipples under carb boots?? The clymer manual doesn't say.....thanks in advance for any reply..this is my first post thogh I have read many !!!
