Carb sync and how it works
Old May 15, 2015 | 03:33 PM
josiahafelix's Avatar
Not that it cant be done with a two guage setup but i recently did a sync with a motion pro and it was pretty simple since all 4 are being synced at the same time, might be worth getting one if your planning on keeping your bike for a few seasons
Old May 15, 2015 | 05:55 PM
Existenz_is's Avatar
Originally Posted by hamlin6
Existenz_is is correct with what he is saying about being mindful about the carb linkages. But our bikes don't have that. On our bikes, there is only adjustment for each individual carb.
I didn't realize the F3 carb was different from an F2 but wasn't sure either way.
I have an F3 carb sitting in the garage but didn't want to remove the velocity stacks etc.
I need to play around with it one day I guess, but I'm tired of messing with carbs lately.
Old May 15, 2015 | 08:21 PM
Fritos's Avatar
I'm currently in the garage trying to get the carbs synced. I'm comparing #3 to #4 right now, and I'm not getting any reading from #4.
I tried flooding each carb with carb cleaner. I was able to stall the bike by flooding #1, #2 and #3. But I was not able to stall the bike by flooding #4.
What does this mean? What should I do next?
Also, I can see gas spraying into #4, more so than the others. I can hardly see it in the others.
Old May 15, 2015 | 08:36 PM
If you aren't getting a reading, then I'd say that that it's not connected properly.
Old May 15, 2015 | 08:39 PM
Fritos's Avatar
I just pulled the throttle, and I'm getting a very very faint reading. I double checked the lines and they're connected properly.
Does this have to do with a float being stuck or something?
Old May 16, 2015 | 09:51 AM
If a float was stuck, you'd know it. If it were stuck open, fuel would flood the carb. If it were stuck closed, that cylinder wouldn't run right.
Benjy68
May 15, 2014 10:52 AM
vanalendur
Apr 30, 2013 04:26 AM
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
scottiekarate17
Jul 24, 2011 03:47 PM
Seadoomanls
Apr 29, 2011 12:10 PM
