Carb Question.....
Old Feb 26, 2010 | 09:58 AM
XxKyle082xX's Avatar
Default Carb Question.....
Last summer bike was busting out in higher RPM's decided to break it all down to clean the carbs and change the plugs and so forth. got the carbs back supposable cleaned and put it all back together.... ran really good for a few good minutes and then died... during running i noticed dramatic rpm change and also gas had made it to the top air tubes between carbs 1-2 and the tube between 3-4. Now when i try to start it it dont do anything but flood itself out and backfire. wondering what might have went wrong if anyone can help me...
Old Feb 26, 2010 | 10:11 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
did you put new plugs in?
were they gap'd the 35-40 they needed to be?
you need to make sure your plugs aren't wet and are firing.
Old Feb 26, 2010 | 10:25 AM
took the plugs out when it started acting stupid and the plugs were soaked with gas. wipped them off and replaced them and still the same thing
Old Feb 26, 2010 | 01:22 PM
willduce's Avatar
sounds like it could be stuck floats in the carbs
Old Feb 26, 2010 | 01:41 PM
CBRmax's Avatar
or adjust the jets i had that same problem and once i adjusted the jets it ran perfect
odano1988
Sep 15, 2015 07:26 AM
sempul
Sep 11, 2009 09:38 PM
bosterfeld
Jul 23, 2009 06:25 PM
cbrstuntin05
Oct 9, 2008 07:36 PM
novaf3
Apr 8, 2008 01:25 AM
