cant pass emissions
RE: cant pass emissions
do they smog a bike the same way they smog a car ? could you post the numbers too please . i want to see exactly what type of emissions your throwing off compaed to what themax and the avg is .. also @ what speeds they are performing the test (cars use a 15 and 25 mph test)
the bike needs to go for a really good hard ride to blow all the hydro carbons that has built up in the engine and exhaust out, if you take it out the morning of the test and really get the revs up you will find that it will probably pass. Bike that only get short runs tend to have higher emissions coz the engine gets coked up.
2 things...
1. Where are you located....so I know never to live there....
2. When getting my racecar through emissions, I'd buy a product called "Guarenteed To Pass". Put it in the tank with some water in fuel treatment stuff, run it till the tank was 3/4 way down then go the emissions. I've taken cars in with all the emissions disabled/removed and gotten better results than new cars get. My old Z24 fast passedwith an "Engine Underpowered" fault from the emissions computer, even though it was a modded motor.
