bought a rear stand, need help
Its a cheap harbor frieght stand that I bought used. I brought it home and found out that the spot where spools go is way to high. I've searched and couldn't find any solid answers. 1 guy I saw just used a round steel through his axle to hold the bike on the stand but I want something better than that. Has anyone used a spool type HF stand on their f3? If so what did you do to get it to work right? Maybe weld a plate to the bottom of the swing and add a bolt on 1 side? I know the frame is steel but is the swing steel or aluminum? I need to get some maintainence done asap and will do the round bar thru the axle for temporary fix but I want something more permenant and safer
![Name: IMG00263-20100328-1724.jpg
Size: 104.6 KB](https://cbrforum.com/forum/attachments/cbr-600f3-17/47991d1501295574-bought-rear-stand-need-help-img00263-20100328-1724.jpg)
i would leave holes in my swing, and do it much like this...
however, i would actually recommend you dodge spools and get a non spool stand. you can get them for 40.00 bucks or less.
dont get me wrong, im sure if you are crafty enough you can pull it off.
(how do you think i got around to what i did heh)
mine worked fine, and im sure yours will as well
that swing arm is beast strong, and a hole through it should not compromise the integrity of the swing as far as i know.
im not a certified mechanic though, i do half my mods intoxicated.
if you are sold on those spolls, get a nut (they sell a weld on version) that you can weld onto your swing, and screw the bolts right in.
