BIKE POWER FIXED !!!!
Old 06-13-2008, 02:52 PM
rider0033's Avatar
Default RE: BIKE GETS NO POWER HELP PLZ!
g3t a t3st l1ght and stop confusing yours3lf
  #22
Old 06-15-2008, 12:31 PM
j
  #23
Old 06-15-2008, 12:36 PM
do you have a manual.
  #24
Old 06-15-2008, 12:41 PM
if you do then check the back of the book for yoUr wiriing diagrams$
  #25
Old 06-15-2008, 12:42 PM
after that then look for yur ignition and fuse box circuts
  #26
Old 06-15-2008, 12:45 PM
your going to have to use the meter and set it to 20v so you can test
  #27
Old 06-15-2008, 12:53 PM
now you need to test your ignition harness to see if the wires are passing current in the on position
  #28
Old 06-15-2008, 12:58 PM
in order to do that you follow your ignition harness to were it connects to the main harness this is a good spot to test put the positive to the wire and find a good conection to for ground. your reading should be 11. volts and higher.
  #29
Old 06-15-2008, 01:09 PM
then do the same with the fuse box there should be constant power of 11. or greater
  #30
Old 06-15-2008, 02:55 PM
SilverF3's Avatar
Ok thanks now i get some help and i can understand it to lol[8D]
Will do early in the A.M then back wit results.
Quick Reply: BIKE POWER FIXED !!!!
