Bike died on me today
So I thought I had a problem with a clogged jet, but I am not so sure now.
I left home and went about 2 miles, when the bike started bogging down, so I give it more and more gas and am staying at the same speed. Next thing I know it just sputters and died. So I coast into a nearby store parking lot and have it sitting there. I try putting on the choke and it actually fires up runs about 5 sec, and then dies tried it again, same story. Next tried w/ no choke, and wouldn't even turn over.
So I am sitting there for about 15 min trying to think what it could be, checking all the fluids etc, then decide to start it. It starts and seems to be running good. I then turn right around and start heading back home. I get back and the bike was just starting to bog down on me.
I am now confused as to what it is. It seems to be a fuel delivery problem. I took the fairings off and when the bike is running I put my hand on the fuel pump and it seems to be working, I could feel it clicking etc.. and seems to go faster the higher the revs.
Any ideas?
I thought it could be a clogged jet, but my carbs were just done like 4 months ago and if one were clogged, I doubt the bike would die, I think it would just be running rough.
Please help!
Any ideas?
Please help!
RE: Bike died on me today
If it seems like it's running out of gas, I'd be thinking Fuel Pump. The fuel pumps on these bikes are not high pressure high volume pumps like on fuel injected bikes and cars. Given that they're 10 or more years old, it's not that much of a stretch to think that they're going bad. My wife's '97 F3 had a problem that seemed like it was time to go onto reserve, but with a full tank. I replaced the fuel pump and she hasn't had the problem since.
just went out and decided to test a few things.
First I tested the fuel pump it is shooting out a bit, then I disconnected the connector for the relay and shorted out the blue/blk and the blk/wht wires, and the pump filled my mason jar in only a few seconds, so I doubt the pump is bad now.
While apart I took out my trusty multimeter and tested some connections. This is what I found.
For the relay connector and the switch on all three wires when testing voltage came out with about 12 volts.
It didn't matter which wires I touched they all came out with about 12 volts.
This leads me to another issue, could it be the relay instead of the pump?
And I have recently installed a gsxr r/r is it possible I soldered the wrong wirer together and that is the cause of my probs? I can take a pic of anything that would help too!
This leads me back to square one.
That "Flow Test" for the fuel pump is what I did as well when troubleshooting my wife's F3. It's flow far exceeded the amount based on the 5 seconds I let it run and the volume it put out. Based on this, I checked the connections and operation of the Pump Relay. I verified the pulsating signal from the ignition system to the pump (its why it clicks). I also replaced the fuel filter, and removed, cleaned and inspected the fuel tank petcock. All seemed well and good, which lead me back to the fuel pump. I think I paid around $107 for a new pump. No issues since replacing at the beginning of summer.
