Another Sync Question
Good day all,
I've looked on previous threads but haven't found what I'm looking for so here goes. I've already bench sync'd my carbs. No issues there. I'm now attempting to dial them in 100%. I've got them all sync'd with the set of Emgo sync gauges I bought. No issues there. They are all working together as they should. My question is, is there a proper value on the gauge? In other words, I have them all behaving in the same manner but should I be attempting to get them all to particular number on the gauges? It seems (and I may be wrong), that adjusting the air mixture screw would affect the value on the gauge. If that is the case, then it seems to be that you could use the gauges to get the proper air/fuel setting. I've looked and can't seem to find that info. Am I way off base with my thinking on this? Thanks in advance. |
whatever your #3 carb is reading is what you need to adjust the rest to. as long as theyre all the same then youre good. as for fueling, no, it really wont make a different in your afr, but you need to have them sync'd up before you start playing with your jetting.
Thanks for the feedback. I appreciate it.
Seems kind of odd that there are no acceptable tolerances from the manufacturer though. |
