Always dead pls help
i had a nice ride i was able to go to 240kph..i just found out 2 small hose inside 3 and 4 carbs are not working then a little bit of cleaning..on the way home i stop 4 times coz of overheating my last stop my radiator hose expoload then a thick white smoke came and my bike was cover by oil i thought i blew my engine after checking i found out all of the oil came in the radiator maybe the old owner pour an oil in the radiator thinking thats the engine...the problem now its so hard to remove all the oil in the water system ive been flushing it for 2 days still the oil is coming out in my water pump i already use some flushing chemicals yet its still their
You need to do a compression test, especially if there is oil in radiator, I hope the previous owner was not so neglectful to let that happen. If all the cylinders fail the pressure test, you more that likely have blown gaskets, if only one of them is out of spec, then as demon says could be the seals.
WhiteHawk
05-30-2013 09:56 PM
