Air guides and hoses...
So, I had all my fairings off the other day and discovered that one of the trapezoid-shaped air filters for the air flow system had no hose coming off it. After researching the service manual, I found that I am missing the Air Guides and hoses that induce air at low speeds (~12mph). The air guides are the pieces that mount the hosing to the underside of the front fairing and I am wondering... does anyone know where I can buy a new/used set of hoses and Air Guides? I truly hate spending money at the dealership. As far as performance, my bike lacks power for about the first 10mph. Is it safe to assume this is due to the missing air guides/hoses...? Any information is greatly appreciated and thanks for the time.
-Six Hundo
-Six Hundo
I think this is what you're talking about?
http://www.cyclepartswarehouse.com/f...1995&fveh=3044
Keep in mind that's for '95-'96. If that's not your year, go to home page and look up yours. Also, as far as no power, do you have a ram air intake box? It's the sloped part connected to the air box in that pic on that site..
Grab the part# off babbitsonline.com, and google around with it.
As for that being the problem, I don't think so. Not having the hose doesn't stop air from getting in, it just stops FILTERED air from getting in. This is generally dangerous, as even a relatively small piece of debris can get in and cause some expensive damage. Maybe the guy that left the hoses off forgot some other things, as well? May want to pull off the tank and airbox and do a decent visual. While your're in there, check your air filter. A slightly clogged one can cause crappy performance at speeds where the Ram system isn't really in effect yet.
I don't think so just as long as there are no cracks in it. Might take it off real quick and give it a nice clean up and a once over to make sure.
+1 on Speedemon's response. But if you're ordering hoses and they're cheap, you may as well get those too.
If the triangular filter is there, you're OK. As for airbox filters, most people don't knwo how to spot a bad one. If it's any significant color other than white (yellow, grey, brown, etc), replace it. Don't wait until a family of mice build a nest in there to decide that it's clogged. Remember, that bike is liek a massive vaccuum cleaner, and sucks a crapload of air through that filter every time you drive. The only airbox filters you can clean are from K&N, and you still need a cleaning kit to do it. I'd throw the filter out and replace it with a K&N one regardless, since you're in there. They're one of the cheapest and easiest performance upgrades you can do. Also, how many miles do your plugs have on them? I doubt they're the problem, but something to think about.
Also, in that airbox, is the little foam baffle in back of the ram intake in place? That's necessary for proper air deflection inside the box.
I'm really starting to suspect your slow jets may be clogged. Replace those hoses and air filter, and if that doesn't do it, you're probably looking at a carb cleaning. That bike should be knocking you to the back of the seat right off the line if you gun it. lagging under 10MPH is not normal at all.
Good News! I found a complete set of air hoses, including the valve assembly, for $35 thru a local on craigslist. I picked it all up tonight, but unfortunately it is raining, so the project will have to wait for tomorrow. I will post tomorrow to update on the progress and outcomes. I truly appreciate the advice and words of wisdom... Thank you.
