air filter
Old Apr 27, 2008 | 01:01 PM
exopforce's Avatar
Default air filter
I am fixing up my bike so i can sell it at the end of this season. I was thinkin of buyin a k&n but its to expensive. Its like 58 bucks and i"m only keeping the bike for like another 4 months. Does anyone know how to clean the filter properly or have a special way of cleaning it so its like new. I also wanted to know when should the carbs of a bike be cleaned out. because my bike has 15,000 miles but the guy before me didnt take care of it so should i do the carbs or let the next person do it. ANd if i should do it by myself how do i unmount the carb from the bike? i saw the tutoriol for it on here but it didnt show how to unmount it from a cbr 600 f3 frame..
Old Apr 27, 2008 | 02:54 PM
redzintimidator's Avatar
Default RE: air filter
Are you having studdering problems, idleing problems, or any other problems that may have to do with the carbs?? If not just run some seafoam in the gas and call it a day. If you can get away with taking an air compressor to the air filter, you should do that..the cheaper the better. To unmount the carbs you just, take the gas tank off, take the black air box plastics off, take the left side panel and access panel off, you might be able to get it from just the access panel. Take a really long *** flat head screw driver and unscrew the rubber connectors that connect the carbs to the head, pull it off, pull off the throttle cables, choke cable, antifreeze cables, and any vacuum lines. remember where these go. You should be free now. Pull it out and follow those instructions. I added a how to clean the idle jet on the end of the first page of that write up, do that and the main jet in each carb along with the rest of the cleaning.
Old Apr 27, 2008 | 02:59 PM
pr0jktmayhem's Avatar
unless you have a cleanable filter you have to replace the filter im sure for it to be really clean.dont know howmuch the paperones cost.
Old Apr 27, 2008 | 03:01 PM
exopforce's Avatar
No the only problem i have is when i idle for to long the bike turns off. but otther then that it rides strong. And do you have a picture of where exactly the screw is becuase i was looking all over and couldnt find it.
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
G3NESYS
Mar 12, 2008 12:25 PM
sc929
Feb 25, 2008 08:15 AM
usndocjaysin
Sep 21, 2007 10:18 AM
