Adding Mesh Behind Fairing Windows???
Im really thinking about putting some mesh behind the fairing window but I was wondering what holds it in place?
Originally Posted by madeincanada123
(Post 754039)
i used epoxy on mine
What type of mesh are you all using, Metal or Plastic?
Thanks SIRR1 |
what i used was aluminum, and i just used hot glue to hold it on
Thanks, I will give your idea a try.
SIRR1 |
thanks for the help
Mesh Screen
2 Attachment(s)
Hey Madeincanada!
I took your idea and added some mesh to the old dog and IMHO I think it turned out pretty good! It's painted aluminum gutter mesh held in place with heavy duty extra strength hot glue. I laid the panels on a table and traced out the holes onto printer paper, cut out a template and then transfered the cut out on the aluminum and then cut out the pattern on the mesh. The template helped me to get the mesh close to the hole size and then I glued a section at a time, cut, fit, trim, glue and then I worked my way around the hole. Thanks for the suggestion, $25.00 bucks in supplies, a few hours a couple of nights this week and it's done! SIRR1 |
i've had this idea in my head for awhile now. but i have no idea where to buy the mesh from. can anyone tell me where they bought their's from? any help is greatly aprreaciated.
I picked up my mesh at lowes in the lumber area. It comes in a large sheet and is about 7 bucks.
| All times are GMT -5. The time now is 06:51 AM. |
