98 f3 won't turn ovee
Old 08-26-2013, 03:17 PM
dad0507's Avatar
Angry 98 f3 won't turn ovee
My 98 f3 won't turn over. I thought it was the rectifier so I replace it and the harness. When you turn the key on and hit start the lights dim but but nothing happens. Not a sound, nothing. And ideas?
Old 08-26-2013, 05:40 PM
derekvercher's Avatar
Clean your connectors under seat. Start with the main one with the 30 amp fuse by battery box. If there's just a little corrosion it will do this. Happened to me and that was it. Also mine has been acting funny as of late. I have to hold the start button down for a moment before the starter starts to turn. Try that too
Old 08-27-2013, 05:53 AM
dad0507's Avatar
I ordered a used starter relay solenoid. It will be here tomorrow. That's where I also thought to start.
Old 08-27-2013, 06:13 AM
74demon's Avatar
Start at the battery. What's you battery voltage standing and while trying to crank?
Old 08-27-2013, 07:31 AM
robuk's Avatar
I second that 74demon, when I got my F3 the battery was dead and it wasn't enough to turn the bike over, but the lights worked etc..
Old 08-27-2013, 01:32 PM
Will.Bass's Avatar
you cant just go throwing parts at it..if your going to buy anything, make it a multimeter so you can find what is actually wrong..you could have an open wire, just like i did, with your exact scenario..
Old 08-28-2013, 04:13 AM
dad0507's Avatar
I tested the battery and it's good. Also the kickstand switch is Ok.
Old 08-28-2013, 12:49 PM
Will.Bass's Avatar
do you have a multimeter or what? do you have a copy of the service manual?
Old 08-30-2013, 05:50 AM
dad0507's Avatar
Yes and yes!
Old 08-30-2013, 06:25 AM
Mrmanr's Avatar
Check all safety switches like kickstand, engine run switch, clutch. Use a light tester. Sure to find break in circuit.
Quick Reply: 98 f3 won't turn ovee
