98 F3 wont start - just backfires
Old 11-02-2009, 01:45 PM
Kuroshio's Avatar
Yeah, but mine says resistance should be 460 - 580 ohms at 20C (68F). And I just checked my downloaded version of the Honda service manual for the F3. It says the same, 460-580. Pretty big difference between the 2.
Not 100% sure that checking the peak voltage would be necessary to find a faulty pulse generator or ICM (which you should prolly check). The Honda service manuals are more thorough than the Haynes. But I think that's because the Haynes banks on an issue showing in other areas before making you dig that deep in.
  #22
Old 11-02-2009, 03:59 PM
millertyme's Avatar
My mistake, i just checked the manual, as i was going from memory, and the resistance that you listed are the same as in my manual.
Do you know a procedure for testing the ICM, or is that a dealer job?
  #23
Old 11-02-2009, 04:10 PM
intiractive's Avatar
Originally Posted by millertyme
plugs are good/new, firing order is correct, one coil pack to 1 & 4, and one coil pack to 2 & 3. the only thing in regards to the coils is if there is a designated terminal for + and -? there are no markings on the coil packs. I dont think it would make a difference, and it was not changed before the not starting issue, just a question.
  • number 1,4 coil: Black terminal - black/white wire. Green terminal - yellow/blue wire
  • number 2,3 coil: Black terminal - black/white wire. Green terminal - blue/yellow wire
  #24
Old 11-02-2009, 04:13 PM
millertyme's Avatar
Originally Posted by intiractive
my manual says the 1,4 pack the yellow/blue terminal is positive, and the 2,3 pack the blue/yellow terminals are the positive.
as does mine, but just curious if anyone knows if the choice of terminals on the coil is significant? i know that if the wires were on the wrong coil packs, then there would be no chance to start.
  #25
Old 11-02-2009, 04:20 PM
edited my post before i saw your reply, look up one
  #26
Old 11-28-2009, 12:04 AM
millertyme's Avatar
well,
the "new to me" CDI arrived today. plugged it in, crossed my fingers, and hit the button...same as before. so, i go back to trouble shooting. i pull the spark plug caps, plug in 4 other plugs, cranked it over, and all good spark. So, i pulled the plugs, connected them to the caps, and cranked it over again. 2 had great fire, 2 dead. so, i take one of the plugs, that is not firing, and remove it from the cap, WOW, the once dead plug is firing. so i reverse the procedure, and that plug fires as well. so, i reconnect both plugs to the caps, and try it one more time. no fire.
So, after screwing around for over a month and buying a CDI in Ebay, i throw the new plugs in the garbage, and go pick up another set. it fires almost immediately. Crisis is over.
thanks to all who assisted, and now i have a good CDI for sale. anyone need one???
thanks
magnumRT
06-16-2013 12:19 PM
MrGoats
03-02-2010 12:46 PM
doogle mcfee
04-12-2009 06:27 PM
paco383
04-06-2008 05:11 PM
xcrusader12
03-24-2007 10:55 PM
Quick Reply: 98 F3 wont start - just backfires
