98 F3 bogging down under load
My 98 F3 with 26k miles reciently cooked its Regulator/Rectifier. I replaced the battery, and the reg/rect.. And now it is bogging down under load @ about 4k rpm. It does not do this in neutral, and didn't start it until I had to limp it home when the reg/rect went out on me.
It does it a little in 1st gear, and very badly in 2nd. I have not had it over 20mph since this problem started in fear of breaking something worse than it already is.
I'm looking for ideas to resolve this issue, and I have not started trouble shooting anything as of yet.
Thanks
Thanks
Not sure if its same as mine but I had something like this happen. Ran fine if I got on it hard in first but then bogged hard in 2nd and would want to die going higher. My problem was a jet came loose and was in bottom of the bowl. Dunno if that's your case but sounds the same. Also if I used choke to start it would flood. Start right up with no choke.
Just did some searching since we have similar problems and came up on this thread.
https://cbrforum.com/forum/general-t...sputter-44367/
My bike is over at my buddy's house 20 mins away and I haven't had time to check the DAI. Hopefully I can get to it tomorrow as Jack Riddley describe the exact same symptoms.
I had moved mine to the old turn signal mounts on the inner fairings.. So I new that exposure to air flow wasn't an issue..
I would get those moved around tho.. Seems to be an issue for a few different people with the same issue. I'd look at moving the to in front of the radiator or attatch them to the air intake for the air filter.
