98 cbr 600 f3 charging issues
hello I'm having an issue with my f3s charging system. I replaced the reg/rec I've replaced the stator and I have hard wired the connections I have also replaved the battery and it still doesn't read above 12.3volts when running. Im at a loss and figured it try the forums I tested the new stator and its not reading out and ac voltage except one of the wires is putting out .56 volts ac. The only thing I think it could be at this point is I replaved the bolts holding the stator to the cover with different hex head bolts rather than Allen head bolts but its not touching any copper wires
