98 cbr 600 f3 charging issues
Old Aug 22, 2020 | 01:36 PM
Rose Doe's Avatar
Default 98 cbr 600 f3 charging issues
hello I'm having an issue with my f3s charging system. I replaced the reg/rec I've replaced the stator and I have hard wired the connections I have also replaved the battery and it still doesn't read above 12.3volts when running. Im at a loss and figured it try the forums I tested the new stator and its not reading out and ac voltage except one of the wires is putting out .56 volts ac. The only thing I think it could be at this point is I replaved the bolts holding the stator to the cover with different hex head bolts rather than Allen head bolts but its not touching any copper wires
Old Aug 30, 2020 | 03:25 PM
Squidlyone's Avatar
Manual for my 96F3 says 15.5V at 5000 RPM is the proper charging voltage. Will not be charging at idle.
MeatHelmet1981
Aug 23, 2013 03:51 AM
15ura
Sep 9, 2012 05:07 AM
rasta51181
Feb 23, 2011 11:24 PM
cbr600f3covina
Aug 28, 2009 03:18 PM
93cbr1000f
Mar 18, 2009 10:25 AM
