97 F3 lighting help
alright so im not sure why this happened but when i turn the key on all the lights come on. im talkin headlight, gauges, front and rear turn signals, and even the turn signal indicators on the dash stay on. im confused the only thing i added was an led signal relay. help!!!!
I would check the relay. Remove it and see if the turn signals go off.
If that is it, try a standard relay. If that fixes it, use replace the new LED relay or use the standard. |
| All times are GMT -5. The time now is 03:13 AM. |
