97-98 F3 jet kit work on 95-96??
Hey guys. Im shopping around since i just got a slip on and my bike now needs a rejetting.
I have a 96 F3, and i found a really good deal on a dynojet jet kit but its listed as 97-98. would it work on my 96?? |
if its just a slip on you probably dont really need to rejet
its popping and back firing so i am sure i need to rejet.
re carb
you dont need to rejet it you need to do a carb job on your bike. in order to do it you need to put a merc guage on it
Originally Posted by 2wheelassassin
(Post 774172)
yes, it will work. the only difference is that the '97-'98 comes with a '142' jet which the '95-'96 doesn't. if you follow the directions, instead of going with the '140' and '142' jets, go with '138' and '140' instead. when you get it and read the instructions, you'll understand what i'm saying.
popping and back firing means you're probably running lean, in which case you should re-jet ASAP. jetting carbs is enough work, but rebuilding you top end is a LOT of work. until you get the jet kit, dont run your bike real hard. and it depends on what exhaust you have, i ran with a gp pipe with almost no packing. edit- you could just go with the 140 and 142. thats what i did. you just don't need to turn the pilot screws as much. |
