97 600 cbr f3 help!!!
Old Mar 2, 2015 | 11:24 AM
Collin Gunter's Avatar
Originally Posted by hamlin6
In case you don't find the diagram, refer to this thread:
https://cbrforum.com/forum/cbr-600f3...ection-127264/
I pulled all spark plugs and they are all sparking..
Old Mar 2, 2015 | 12:41 PM
Then I go back to the carbs being suspect. I understand you looked at them. But did you remove them and pull the bowls? That is where all the jets are tucked away. Also, if you remove the tank and air box, can you see an arm like thing moving on the carb rail when you the choke lever back and forth?
Old Mar 2, 2015 | 12:44 PM
Yeah it moves when I pull the choke
Old Mar 2, 2015 | 12:47 PM
Then at least your choke is trying to actuate.
The only other thing other than dirty carbs is if the battery isn't strong enough. But I'm leaning towards the carbs being the issue.
