96 F3 Clutch Perch
96 F3 Clutch Perch
Hi guys,
New to the forum. Lots of great info. Picked up a 600 f3 and it was a write off so I had to fix a couple of things. One question I have is I need a new perch for the clutch handle because it was dropped and cracked. I checked ebay and there is a few options, but they are for a f4. Will this work ?? Any feedback is greatly appreciated.
Cheers
Cheers
Different part #s according to RonAyers...
But I think it'd be easy to make it work because looking at levers on eBay, they interchange between the F2,F3,F4, and F4i along with a lot of other Honda models...
If it simply came with a different bolt on it, it'd have a different part # from the factory. The clutch perch is incredibly simple...
Do you still have the clutch switch? That's what it depends on. Can you use the same one, or, at least use your OEM plug on the new one...
02f4irider
03-06-2009 07:50 PM
