96 to 97-98 rear
Old Nov 10, 2008 | 10:05 PM
oldschoolsdime92's Avatar
Default 96 to 97-98 rear
What needs to be done to convert a 96 f3 rear to a 97-98 rear?
Old Nov 11, 2008 | 03:42 AM
bigjohnstud4200's Avatar
Default RE: 96 to 97-98 rear
I thought 95 - 98 F3's were the same?
Old Nov 11, 2008 | 05:35 AM
the tail lights are different. the 97-98 has alittle more modern looking tail light.
Old Nov 11, 2008 | 07:01 AM
Northernfirepower's Avatar
The seat is diffrent also, the 97-98 hugs the tank with forward points on each side. The tail section sides and center are also diffrent to fit the 97-98 tailight
Old Nov 11, 2008 | 08:31 AM
redzintimidator's Avatar
this has been asked at least 40 times in the past year...search!!!
Old Nov 11, 2008 | 09:35 AM
i figured it probably has been,but hey it happens!
Old Nov 12, 2008 | 07:33 PM
Witchking's Avatar
I did the same thing to my '96. I went with the rear of a '98, although I think the 97's are the same.All you have to do is switch out the undertray for a '98 model, and that undertray will allow your rear plastics to mount up to the snap-in holes. You'll also need a rear tail light, and of course the plastics. I'm not sure about the turn signals, as mine are flush mounted to the plastic sides, so I didn't have to worry about it. I knew very little about bikes when I did it, and it really was a piece of cake.
good luck.
romanboy
Jan 6, 2013 07:57 PM
