96 600f3 velosity stack questions???
here is the link that i found for velosity stacks. http://www.velocity-of-sound.com/
so noone knows if they are an affective horse power gain? or has put after market stacks on before?
Additionally, I would really not recommend this be a FIRST mod in any event. You mentioned that all you have is a V&H exhaust, so you might start with jetting your carb. There are some kits from FactoryPro that are really great, and others on the market too. Another option for a quick performance gain is an ignition advance - again from FactoryPro. Either of these options will get you a lot further with performance than adding aftermarket velocity stacks - and an ignition advance is a cheap mod that will be really noticable (try out a +4). Another option is to do a 520 conversion kit and go -1/+2 on your sprockets. Again, this is a VERY common mod that will give you quite a bit more acceleration and low-end power.
If after jetting your carb or doing some other modification that changes your A/F mixture, you find the airflow is insufficient or a dyno reveals that it is significantly hindering your performance, then (and ONLY then) might you try a set of those stacks. I would venture a guess, though, that you will never be in that position.
Good luck with the F3. Cheers!
