637 engine winter project.....
Old Sep 13, 2007 | 08:31 PM
Scrufdog's Avatar
Default 637 engine winter project.....
So I'm thinking about building a 637 this winter. A few questions while I look around and consider it.
1. Does anyone sell a complete 637 kit? Pistons, pins, rings and such....
2. Are there complete engine gasket kits available?
3. I've read that the 98 engine was more powerful than the 95. I this due to the carbs or does it have anything to do with the bottom end? Will a 98 plug right into the 95 setup with sensors and such or does anything need to be changed?
Thanks
Old Sep 13, 2007 | 11:34 PM
ptowntsi's Avatar
Default RE: 637 engine winter project.....
why not sell your bike and get a 636? problem solved. you can get like 2500 for yours i'm sure easily maybe 2800, and an 03 636 will go for like 4700-4800.
Old Sep 14, 2007 | 07:27 AM
kjohnson's Avatar
That's what I have in my racebike.
Price everything separately,you maycome out ahead.
Word of warning,the Cometic gaskets are known to be faulty,especially the head gaskets.Use an OEM gasket kit,then cutthe head gasket2 mil over.
The 98s do have a little more power.It is due to the carbs,and the flow of the head.The bottom ends are the same. Gota get back to work.I'll finish this later
Old Sep 14, 2007 | 12:08 PM
kjohnson's Avatar
Yeah,the 98 will "plug right in".
Old Sep 14, 2007 | 01:51 PM
madmike01uk's Avatar
I heard the 98's have like 1 bhp more, if this is true it is probably not worth the work.
Old Sep 14, 2007 | 05:37 PM
Scrufdog's Avatar
ORIGINAL: kjohnson
Is the 637 a very streetable engine still? Or would you only really use it on the track?
I figure If I have a choice when looking for a motor to build, I might as well get the best one I can find, even if it is only 1bhp
hss2010
Feb 11, 2012 07:30 PM
marc0011
Jan 31, 2012 12:55 AM
Dblock55
Nov 18, 2010 05:07 PM
STREETFIGHTER88
Apr 1, 2010 12:22 PM
gottabfordtough
Apr 8, 2008 09:19 AM
