-1 front sprocket
Old Dec 16, 2006 | 02:39 PM
PatsCBR's Avatar
Default -1 front sprocket
Ok guys I just got my -1 front sprocket.. How hard is it to install?? Any tricks? Can you get the cover off with out taking the fairings and how long does the whole job take..
thanks
Patrick
Old Dec 16, 2006 | 03:56 PM
KidCr3nshaw's Avatar
Default RE: -1 front sprocket
I would imagine you could just loosen the rear tire and move it way forward giving you some slack and slide the chain off the sprockets - I wouldn't think that would be a real problem.
You'll have to take off the lower fairings, or at least drop them to the floor. The front sprocket is nothing at all, slides on and slides off.
Old Dec 16, 2006 | 05:02 PM
gixxereater's Avatar
Nothing at all? Come now, they are simple in the way the physically go on and off, but use an impact to get it off as it will be tight as ****. A breaker bar and socket/ratchet will work but you will probably have to block the rear tire from rotating. Put it in gear, in neutral the engine wont hold it enough to break it loose.
Old Dec 16, 2006 | 06:06 PM
Sorry, I don't think of removing a nut as much more than... removing a nut.
I used a 4-way on mine - easy peasy japaneesey.
Old Dec 17, 2006 | 12:16 AM
PatsCBR's Avatar
Thanks guysI was just wanting to know if I had to remove the fairing.............
Old Dec 17, 2006 | 01:18 AM
How old is your chain? If you have a worn or near worn chain, your new sprocket wont last long. A bad chain will eat new sprockets and vise-verse. Just FYI. Most of the time they are changed in conjunction with one another. Good luck. You will like it.
Old Dec 17, 2006 | 02:12 PM
PatsCBR's Avatar
Thanks Gixxs
The bike has only 5K on it and its near perfect or I would replace everything....
Old Dec 19, 2006 | 08:05 PM
4nicho's Avatar
I have -1 on my F3 and love it. Easy to do, but gives it a little more power on the low end. Messes with your speedo so watch out!
Old Dec 21, 2006 | 01:03 AM
uffitz56's Avatar
About how much does just the -1 front affect your speedo?
Old Dec 23, 2006 | 08:12 AM
Kingsolver's Avatar
my 98 f-3 with -1 is about 1500 rpms higher now. I think on the freeway its 5th gear, about little over 7000 rpms and speedo says around 72-75 mph- I think actual is closer to 62- 65mph. Gonna ride next to my truck on the freeway when weather gets nicer to verify.
