Wish I Had Better News
Old 03-03-2011, 04:52 PM
reydelaplaya's Avatar
Default Wish I Had Better News
Well it's been about 8 weekends now messing with this F2, and no luck. Me and my neighbor have put in many hours and have thrown quite a few cases of beer at it, but it still won't start.
It's got spark, it's got gas, and it's got air, but it's got no life to it for the moment. Every once in a while it kicks, but it just doesn't get going.
Just figured I'd update... that's all.
Hope everyone is having better luck with theirs and starting to get good riding weather.
- rey
Old 03-03-2011, 05:20 PM
DrAwkwArD's Avatar
Don't know much about these bikes but are the vacuum ports behind the car's on the heads blocked properly? I worked on an older R6 recently that wouldn't start for the dude and first thing I noticed was a couple vacuum caps missing...plugged them and it fired right up.
Who knows.
Old 03-04-2011, 12:40 AM
enko's Avatar
My first time ripping it apart I forgot to hook the vacuum line back to the petcock... took about 30 mins to figure out wtf happend. Now I never forget it lol
Old 03-09-2011, 12:59 PM
ic2283's Avatar
yeah dude make a check list, run through it and double check. The manual has a pretty good troubleshooting guide
Old 03-11-2011, 01:18 PM
JesseAwesome's Avatar
I've seen this happen before.
Check your firing order sparky :P
Old 03-11-2011, 01:31 PM
adrenalnjunky's Avatar
1-2-4-3, in case you didn't know
Old 03-13-2011, 02:15 PM
You know... that's not a bad idea. I disconnected the plugs once during cleaning, but I thought I made sure I put them back were I found them. But who knows? Maybe so, I hadn't given that a thought!
Good call, let's see!
Old 03-13-2011, 02:17 PM
Lemme go take a look. Thanks!
Old 03-13-2011, 03:11 PM
#1 cylinder is on the left of the bike when seated on it as well, just in case you didn't know.
Bike fires 1-2-4-3 as i mentioned earlier. Cylinders 1 & 4 should be connected to the coil on the right side of the bike, and that coil should be plugged into the connector that has a Yellow wire with a blue stripe in it. The coil for 2&3 has the connector with the Blue wire with the yellow stripe.
Old 03-14-2011, 08:26 PM
Post up man, I'm waiting for you to tell me that i'm right
Quick Reply: Wish I Had Better News
