Why why why : (
I repaired a mount point on the rear panel of my F3 using a thing called tigers hair. It is bondo with fiberglass in it. Mix it with the hardner and apply it to a clean sanded surface. If you build it up from the inside over a wide area and sand it down to a uniform level I bet it would hold. My repair has held for over a year so far.
I got the "Tigers Hair" from a paint and body supply shop.
Good Luck!
Mikey
Good Luck!
Mikey
EIther way, plastic welding is still cheaper than the 120 you spend and still strong.
