What are the two taps/screws
Old May 24, 2015 | 06:14 PM
Ricky Rowland's Avatar
Default What are the two taps/screws
Hi I have just got a cbr600f2 and not sure what the two tap/screws are for on the left hand side of the bike that are accessible without having to take and panel off ect
Old May 24, 2015 | 10:09 PM
Mattson's Avatar
Gonna need just a wee bit more info than that...
Old May 24, 2015 | 10:57 PM
Existenz_is's Avatar
You're losing your touch. You should know exactly what he is referring to without him even having to ask!
Old May 24, 2015 | 11:05 PM
Mattson's Avatar
Only things I can think of are either a place for the helmet lock or the two pins that point down below the cargo rack which are meant for fixing points for a strapping net.
Old May 24, 2015 | 11:49 PM
I was thinking maybe something to do with the inspection/access panel...
Or rear set....
Old May 25, 2015 | 03:14 AM
well I think on if the fuel tap and other mixure screw idle screw but not sure
Old May 25, 2015 | 04:16 AM
Need. More. Info.
On the frame?
On the motor?
On the carbs?
On the body?
More details needed.
Go here and download the F2 manual, from my google drive.
https://cbrforum.com/forum/f2-tech-9...on-1-a-153193/
Post up pics if possible.
Old May 25, 2015 | 04:25 AM
Are you asking about the vacuum ports like these?
Old May 25, 2015 | 08:32 AM
Migge's Avatar
My first thought was actually that he's referring to the petcock and idle screw...
Old May 25, 2015 | 11:01 AM
Phil314's Avatar
I think you are talking about the fuel petcock **** - should be marked on - off -res. It turns the fuel on and off and to reserve (when you get low).
Second **** is idle speed adjuster. It's not an idle mixture. very different. You shouldn't normally have to adjust this. It's more a set and forget ****.
