What size front sprocket bolt?
Getting new rear tire for my bike on Wednesday, so whenI do the teardown on the rear I'm replacing front and rear sprockets as well as chain. I already have the two wrenches that fit the rear wheel, but need to know the size on the front sprocket. I have an impact gun as well as sockets up toa point, but probably not anything larger than 17mm.
PS, already did a search and found sizes for other bikes, but I want to be sure.
TIA
I think the front sprocket bolt is a 14mm,
but I'm not positive if you have a generic metric socket set itshouldbe in there.
And you might need an extension or maybe a deep socket will do.
Cool, thanks. That would be the same as what I found in a search that showed for other bikes.
I have a set that I'm sure includes the 14mm, give or take a few sizes. I was worried that it would be something like the rear axle nuts and I wouldn't have the size and all the stores would be closed.
