What did I do wrong?
Here is a shot of my carbs.
Here is a close up of the red circled part that im pointing at
I put the airbox back together and hooked up all breather/vaccum lines that I disconnected and I put the tank back on. I went to start it and gas started leaking from that pointed nozzle part I circled in the close up. I dont remember any line hooking up to that. Why was it leaking? Thanks
Is your bike a california model?
Where the circled piece is, on my bike, is just a hose "T" to join the 2 hoses to the main fuel line.
I've never seen that piece before, if you could remove it and take some better pictures it might give me a better idea.
Cali model. I started it up and its leaking from that nozzle. Im stumped, It was running perfect. All I did was remove the tank and air cleaner, and I put it back exactly how it was before. Ill try to take a better pic for you.
I think its called the purge control valve
Its under the CANISTER (AC) schematic
http://www.bikebandit.com/houseofmot...2-1991/o/m2040
It does look like something belongs there but I dont remember disconnecting anything from it and I keep double checking and I cant find any loose hoses. Thanks anyways Hershey I think Ima have to look at someone elses F2 or F3 to figure it out.
