We've made a mess for ourselves. CBR 600 F2 1993
Old 06-19-2018, 09:37 PM
Red face We've made a mess for ourselves. CBR 600 F2 1993
Me and a friend picked up a 1993 CBR600 F2 on the cheap planning to enjoy a project together. It was running when we got it but had an awful vibration above ~8k RPM. Here's our story.
  1. The guy we bought it from suggested it needed a valve gap adjustment so that's where started. We put together this spreadsheet: Google Sheet
    1. We used a Shim kit which ran out of a few sizes so we couldn't get them all in spec. However, we got most of them in spec or pretty close to it. (See "Final" section in the bottom right for the results.)
  2. After that my friend put about 3000 miles and a set of new tires on the bike.
  3. He noticed the bike was burning oil.
    1. There was a funky burning smell in the gas (not sweet) with a little white smoke
    2. He checked the oil level and kept finding it was low and adding more oil.
      1. I don't really have an idea of how fast it was burning.
    3. The coolant level didn't appear to be changing. (I've read white smoke usually means coolant?)
    4. No noticeable oil/coolant contamination.
  4. Did a compression test.
    1. #3 had 0 compression
  5. Took off the head and found the biggest hole in an exhaust valve I've ever seen. (Also the only hole I've ever seen, this was my first time working on an engine.)
  6. Replaced the valve and the head gasket.
  7. We really screwed up here. When setting the timing this time around we were overly confident (and didn't follow the manual) about which marks had to be lined up and made a mistake.
    1. Instead of lining up the "TI:" mark on the crank, we lined up the "I" mark
  8. Cranked the engine about 30 times and heard an loud clanking (pistons hitting the valves)
    1. Yes it took this long for us to think "Maybe we should investigate"
  9. Realized the mistake we made and fixed it.
  10. Instead of taking off the head to investigate we performed a leakdown test which showed <10% on all cylinders.
    1. We assumed there weren't any bent valves with these results.
  11. With the correct timing the engine started right up.
    1. There was a persistent awful rattling noise we believed to be the cam chain. We've read that the tensioners are prone to failure.
  12. After about a minute the engine warmed up and the a lot of white/gray smoke started coming out of the exhaust. It wasn't very thick and smelled burnt.
    1. We hoped was that this was residual oil and only temporary.
  13. We planned to do a carb sync, so the engine was idling for about 8 minutes before it began to run very rough.
  14. This is when we heard the worst noise ever... A metal cracking noise followed by an abrupt stopping of the engine.
  15. So we took the head back off and this is what we found.
Top of piston #3
#3 Valves
#3 Valves
#3 Valves
So...... What happened?
Did we mess up the valves with the bad timing? If so why did it run fine for 8 minutes? Why was the leakdown test fine?
Did the cam chain slip enough cause this? (The timing was PERFECT after we fixed it.)
We obviously need a new head considering the gash in that valve seat.
There are some gashes in the top of piston #3 but the cylinder walls seem to be undamaged. Will the new head be enough to get this running again?
I've been lurking in this forum for a year and all of the information on here has been incredibly helpful!
Old 06-20-2018, 07:49 AM
Phil314's Avatar
That is awesome, but not in a good way.
I'm guessing when the time was off the first time, you bent a valve. Even with a bent valve the bike will still idle, but it's is stressing the valve every time it closes. Eventually (8 min in this case) the valve can stress crack and break off. And lot of bad noises and chunks.
I seriously doubt this had anything to do with a camchain. Not sure how you got a good leakdown on this.
You need a new head for sure. You could try smoothing out the piston face. Depends how bad it is after you clean it up. You don't want any sharp edges or you'll get detonation and could end up back at square one again. Or you could put a just swap another piston in. Also check the connecting rod to make sure it's not bent. It all just depends if this is a fun project or you want a bike to ride.
Old 06-20-2018, 10:21 AM
I'll clean off the piston soon, try to smooth it down and post another pic.
Should I be concerned about the smoke I was seeing? Could it have been oil leaking past the valves after we bent them?
If it's burning oil from somewhere else i want to make sure we fix that before putting the whole thing back together.
Also, how clean does the head gasket surface have to be? There were some black bits from the old gasket but they were smooth and could barely be scraped off even with a razor blade.
Old 06-20-2018, 11:18 AM
tentacleslap's Avatar
Agree. Great post
Also, kudos for making the decision to take on an engine. It may not be the easiest or cheapest way to learn, but it's definitely the best. Don't feel too bad - I destroyed the first engine I took apart, but it made the second one go much better. I'm sure lots of other guys would say the same
As for the diagnosis, Phil is probably dead-on. I'd be worried about the cylinder walls. Anything that'll catch your fingernail is too deep to reuse without honing. Those metal chunks can be bad news if they get into the oil system.
Before buying a head, I'd check prices on a complete engine. If it's only a couple hundred extra, I'd go with a full block rather than risk hidden damage elsewhere, and then you get a spare engine to mess around with
If you're comfortable with a bit of risk, you could be fine with a new head, but before ordering parts I'd try and get a look at the pistons, conrods, pins, and rings for damage to make sure that it was worth fixing. These type of repairs can spiral
Old 06-20-2018, 04:12 PM
Phil314's Avatar
That piston looks like it's got a pretty good divet in it. That will be hard to smooth. It really boils down to if this is more of a project. Then smooth it an try it. If you're trying to fix the bike to ride, them put a new/used piston in.
The smoke could be a couple things. The bike could have had previous undiagnosed problems like a cracked ring. Could have been a cracked valve guide from a bent valve letting oil drip in. Too hard to tell.
Head gasket should be clean and shiney. All old bits of gasket and stuff need to be removed or you risk it leaking.
Personally, I'd pull the piston, check the walls and rod. If good, I'd put a new used piston on with the old rings. Then a new head gasket and a good used head. Spec everything, check the valve clearance. Turn the engine over by hand first. Then do a compression test and if everything checks out, fire it up and run it.
Old 06-20-2018, 04:39 PM
Thanks for the tips. I only have time to work on this on weekends so I'll take your advice and post an update in a few weeks.
Old 07-31-2018, 08:17 AM
heresolong's Avatar
I wouldn't even try to save this engine. I did the same on a Toyota pickup (except for the part where it was my fault ). Lost a head gasket, damaged the head and pistons, tried to save the engine. The roughness that results from trying so "smooth" out pistons and head chambers results in significant amounts of inconsistent burning of gas inside the cylinder. The truck ran OK for about a year and then just started having problems again and I had to put in a remanufactured engine anyway. Would have been better off saving the time and money and going straight for new engine. You would not only need a new head (this one does not look rebuildable to me) but also new pistons. This becomes very expensive very quickly.
I would look for a wrecked bike. Since you only need the engine and the since the engine is unlikely to have been damaged in a wreck (other than side covers which you can save from yours) you might be able to pick one up dirt cheap. I got one for $150 a year or so ago.
PS Don't feel too bad. As mentioned by tentacleslap this is part of the learning process. I've screwed up my fair share of stuff over the years, but eventually it led me to become a professional Harley mechanic and I think I've done well. So long as you learn from each screwup.
Old 12-15-2018, 05:54 PM
The hard lessons are the best learned. I think you bent a valve right away and things went downhill from there.
If you just want to get going again, buying an engine from a reputable seller is the way to go. The cost will likely be lower than what you'll spend fixing what you have, especially if you do it correctly. Besides, an engine is pretty cheap when you don't need the starter, alternator, etc. You'll be able to re-use that stuff.
If what you want is to build an engine (way cool) then do it properly, hopefully with the help of someone who's done it before. You'll also need a machinist. You can get someone local or ship it to a place like Power Seal (the place I use).
I had a race engine die on me where the damage was nearly identical to yours. The top of the exhaust valve broke off and stood on edge which drove it into top of the Piston as well as trashing the cylinder. In the end it with was a head, valves and valve job, new piston and a bore. This was on a two-valve single and I was in it for a few hundred dollars, so you can multiply that by at least four.
Old 12-17-2018, 10:13 AM
Default Thank everyone!
We decided to get a new (used) engine from ebay for about $600. We've put a few thousand miles on it since then and it's still going strong.
It has been a great learning experience and I definitely won't hesitate to get into another engine in the future.
Thanks for all the advice everyone!
ndiy12
09-19-2014 12:32 AM
NIK600RR
06-03-2010 01:48 AM
rangerscott
04-25-2008 09:45 AM
dwhite645
04-10-2006 03:33 PM
doncollins
12-22-2005 05:49 PM
Quick Reply: We've made a mess for ourselves. CBR 600 F2 1993
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
