Two Questions: 91 F2
Old 11-16-2006 | 09:04 PM
C2H5OH's Avatar
Default Two Questions: 91 F2
Wanna upgrade the brakes.I cant find any place that sells aftermarket calipers.Anyone know of a place?Or can I just get some better brakes off a different model bike without doing alot of modding?
Also,does anyone know who makes these fairings? They're old and I love the look of them and want a new set exactly the same.
Old 11-18-2006 | 06:29 AM
BlkF2's Avatar
Default RE: Two Questions: 91 F2
i dont know of any better calipers, but you can upgrade your pads and rotors, and a good fluid flush always helps.
I dont know a thing about those fairings but if you find out what they are let me know.
Old 11-18-2006 | 03:09 PM
Bobthebiker's Avatar
I dont know of any caliper upgrades either, unless you wanna swap out your front forks to a set off an RR. that'll get you newer higher performance rotors calipers, and everything. sintered pads should get you some better performance in braking, as should fresh brake fluid and a good bleeing of the brakes.
Old 11-18-2006 | 03:28 PM
gixxereater's Avatar
+1, replace the pads with some EBC HH pads. They bite HARD!! And flush the system and lube the pivot on the lever. It'll be like a new bike. I also dont know about he fairings. Sharkskinz? Hotbodies? Dont know forsure.
Old 12-02-2006 | 02:17 AM
racer212's Avatar
EBC makes a whole superbiek setup thats the ****. 320mm floating rotors, spacers for your calipers, and some trick Pads. Use good lines with it and you'll have all the brake you could ever want.
cbrmonster
How-To: Mechanical
11-13-2008 02:07 AM
bigboi18184
11-09-2008 06:58 PM
SNOWMAN
02-05-2008 09:10 PM
karty
09-03-2006 02:15 AM
Paper Chaser
08-03-2006 06:24 PM
